Last activity: 27 Apr 2020 12:04 EDT
Unable to access VM url
Hi Team,
I am not able to access the url mentioned in VM. But system responded when pinged.
Please find screenshot attached.
Updated: 14 Jun 2021 7:38 EDT
Tried with "host-only adapter" but no luck.
The Tomcat Sever in the VM might not have come up cleanly.
Try rebooting the VM and check if the issue persists.
Tried, no luck.
What adapter are you using? I am assuming Bridged, I see you have tried Host-Only. Did you try NAT?
Once the system comes up how long are you waiting before you test the URL in the browser window? You should wait at least 4 minutes for the app server and db server to start up.
Sean
Pega Academy Self-Study Support Team
With NAT configuration, IP address shown in VM is not reachable.
Are you trying to access this from your company network or from home?
I tried import ova file in vmware player also with all the network adapters. VM url is not up.
Could you please check if "Host-Only Adapter" is checked in the Network settings of Virtual Machine.
