CGI
Last activity: 26 Jul 2023 13:19 EDT
UiPages Creation
How to create a UiPage if we dont have Pages option in appstudio??
@AnilkumarManepalli18 did you already find the following posts?
Follow below mentioned options to get pages option in app studio.
1) Launch App Studio
2) Click on Preview Button which will be avail next to application name in header.
3) After that Click on Design toggle icon which will be avail in app studio right side header.
4) After you clicked on design button you would be able to see pages option getting displayed below app studio header.
Please refer to this link:
https://academy.pega.com/topic/creating-page-application/v2
In the header of App Studio, click Preview application, and then enter the design mode by clicking Design.
In the upper-left corner of the window, expand the Pages menu, and then click New.
In the Create new page window, enter a unique page name, and then click Submit.
CGI
@AnilkumarManepalli18 please run a Tracer and check the logs for the full error stack when you replicate the issue.
Can you provide more details if all Admin users have this issue?
Anilkumar Manepalli
CGI
@AnilkumarManepalli18 please log a support incident for this, and provide the INC number here so that we can help you track it.
Do you have any updates regarding this issue ?
We are facing the same problem now
CGI
I suppose if an application is based on React UI [React based UI or Cosmos React UI / Hybrid mode], I don't think pages option will be available. You may need to navigate to Channels-> Portal. After selecting the portal, you can see the landing pages and custom pages options under content tab. You can navigate to required option and add a page.
Thanks for the answer..
No, the application is based on Theme-Cosmos. I can create/add the landing pages but not not any new pages.
Not sure... but may be I can switch to Desginer Studio and create a new harness under the same class and a section ... then go back and try to select this one from AppStudio (or even from Designer Studio) but not sure I can see this page there in the list.
Capgemini
AT
@AnilkumarManepalli18 I have been looking around App Studio to find a way to add new custom Landing Pages to my Navigation Menu.
Unfortunately, none of the docs or academy articles describe this in teh way that 8.7 is allowing you to do it. Certain buttons are not visible, or options in lists are just not there.
The way I was able to do it was to go into the Developer Studio and create a new Harness Rule in the UI-Pages class of my application. After I created it, I just had to set the rule as a relevant record so it could be used in App Studio.
Tadaa, the new Harness was available immediately in the list of addable Landing Pages in my channel configuration.
Maybe this helps,
all the best
@EricSchranz90 thanks so much for your help and explanation in this post!
I have checked the documentation and am happy to pass on any suggestions you have.
Unfortunately for the pre-Pega 8.7 documentation we will not be making any changes.
Perhaps you can help guide me where you think your steps should get included in Creating a landing page for an application?
Virtusa
Now are you able to see Pages button in your application.
Virtusa
Hi Anil,
I am not able to see the pages option is not coming in my application.
Can you please help do needful.
