Belvnesheconombank
BY
Last activity: 15 Jun 2017 3:59 EDT
Tracer viewer tool issue
Hello! I downloaded tool from https://pdn.pega.com/use-tracer-viewer-tool-summarize-tracer-xml-output and can't open xml with trace.
Here is the log message:
Loading C:\Folder1\H455F7E11B6A95AB4EE1715784FAAC0C6.xml
Processing C:\Folder1\H455F7E11B6A95AB4EE1715784FAAC0C6.xml into C:\Folder1\H455F7E11B6A95AB4EE1715784FAAC0C6.pk
Reading event types from C:\Folder1\H455F7E11B6A95AB4EE1715784FAAC0C6.xml
0 events
Context: //Context contains a confidential data, so I delete it
Uncaught exception:
Traceback (most recent call last):
File "tracerGui.py", line 615, in OnOpen
File "tracerGui.py", line 604, in open
File "tracerGui.py", line 472, in OpenTracerFile
File "tracerGui.py", line 220, in __init__
File "tracer\tracerLoad.pyc", line 8, in load
File "tracerTake.pyc", line 191, in tracerTake
File "tracerTake.pyc", line 145, in scan_for_event_types
File "xml\sax\expatreader.pyc", line 211, in feed
File "xml\sax\handler.pyc", line 38, in fatalError
SAXParseException: <unknown>:84:69: not well-formed (invalid token)
I also renamed the generated XML and this did not help. Replacing the XML into tracer viewer directory also didn't help me.
This error has appear also when I try to open XML generated with Interaction option (event type) enabled.
So... I create simply activity at Personal Edition environment with two simply steps:
1. Obj-Browse (Operators from PR_OPERATORS into tmp pagelist (18 records in DB table))
2. Show-Page (tmp pagelist with result records)
Then I run the tracer and I run this activity (Interaction option was disabled). So in tracer I see two rows: Activity Begin and Activity End as second step. Then I save generated XML and try to open this file via tracer viewer and file was opened successfully (possible because of data structure is very simple unlike generated XML from production server).
So... maybe problem exactly in Context? Maybe one of many tags not closed correctly and in tracerViewer log this message SAXParseException: <unknown>:84:69: not well-formed (invalid token) informs me about position of incorrect tags or something like this? And maybe I must fix generated XML?
Thanks for help!
