Trace App Requestor
Hi Team,
From XYZ application, they are making a service call to our application which will run few rules in our system. I just want to trace
How can we trace in this scenario ?
Hi Team,
If you can restrict the call to a particular node, you could open the service rule on that node and trace it. For example, when you open a Service SOAP or Service REST rule in Designer Studio, you should see a Trace option in the Actions menu.
If this is a single node, you can directly trace service rule.
If this is a multi node, you need to restrict to one particular node and trace it.
