There is no 'Client Credential Provider' secure data store available.
Hello. I'm trying to test a Client Credential Provider I created, following the C# sample provided in the Robot Runtime 19.1.34 installation. I believe I've configured everything correctly in CredentialManagerConfig.xml and CommonConfig.xml, but when the RPA Service attempts to start work, I get the following in RpaService.log:
Info | 03:55:37.845 PM | 1 | MTA | Service | *** Initializing Service ***
Info | 03:55:37.861 PM | 1 | MTA | Service | .NET 4.5 or higher framework is available. Web connections will support TLS 1.1 and TLS 1.2 protocol.
Info | 03:55:37.877 PM | 5 | MTA | Service | Service starting...
Debug | 03:55:37.892 PM | 5 | MTA | Service | Current time zone: Eastern Daylight Time
Info | 03:55:37.955 PM | 5 | MTA | Service | Service Mode: Scheduled
Info | 03:55:37.955 PM | 5 | MTA | Service | Runtime launch retry feature: enabled
Info | 03:55:38.189 PM | 5 | MTA | Service | Service started.
Debug | 03:56:38.206 PM | 6 | MTA | Service | Scheduled work processing
Debug | 03:56:38.206 PM | 6 | MTA | Service | Scheduler is currently in scheduled time interval
Info | 03:56:38.221 PM | 6 | MTA | Service | Discovered 'Protected DPL Data Store' secure data store.
Info | 03:56:38.221 PM | 6 | MTA | Service | Discovered 'Protected CyberArk Data Store' secure data store.
Info | 03:56:38.237 PM | 6 | MTA | Service | Discovered 'Protected Machine Data Store' secure data store.
Info | 03:56:38.237 PM | 6 | MTA | Service | Discovered 'Protected User Data Store' secure data store.
Debug | 03:56:38.237 PM | 6 | MTA | Service | Discovered 4 secure data stores.
Info | 03:56:38.252 PM | 6 | MTA | Service | Selected 'Client Credential Provider' as default secure data store for Machine scope.
Error | 03:56:38.268 PM | 6 | MTA | Service | There is no 'Client Credential Provider' secure data store available.
Error | 03:56:38.268 PM | 6 | MTA | Service | Object reference not set to an instance of an object.
System.NullReferenceException: Object reference not set to an instance of an object.
at Pega.RpaService.Common.CredentialHelper.ResolveStore(String entryName)
at Pega.RpaService.Common.CredentialHelper.GetCredentials(String entryName, String& domain, String& userName, String& password)
at Pega.RpaService.Service.RpaService.DoScheduleWork()
Debug | 03:56:38.284 PM | 6 | MTA | Service | Scheduled work processing - done
I've attached CommonConfig and CredentialManagerConfig. What might I be getting wrong?
