Atos
Atos
Atos
Posted: Jun 14, 2021
Last activity: Aug 7, 2023
Last activity: 7 Aug 2023 10:34 EDT
Theme-Cosmos:02-01-01 -- Broken "Edit" button
After upgrading to the newest Theme-Cosmos v02-01-01 the following issues occurs.
- Create a new case
- Press "Edit"
- Submit your changes
- All is good, yay!
- Create a new case
- Press "Edit"
- Cancel the task
- Press "Edit" again
- The following message is shown: "By performing this assignment, you are disabling stage SLA and stage/case-wide local actions for the current stage of your work object."
If you run into this issue, revert back to the "EditAction" section of Theme-Cosmos v01-01-01.
Good luck!
***Edited by Moderator: Pooja Gadige to add platform capability tags***
***Edited by Moderator Marissa to update Content Type from Discussion to Question***
