Test Suites and Data Pages
Why can you not include test cases for data pages in a test suite?
Message was edited by: Marissa Rogers - added category
Hello
I am not an expert on this , but as per the help guide here : https://community.pega.com/sites/default/files/help_v719/procomhelpmain.htm suite it seems the rules which can be part of test suites are Activities, Decision Tables, Decision Trees, Flows, and Service SOAP service records
I am also facing the same issue. The data page rule allows to create test cases for itself but while creating Test suites, the option to choose "Data Page" under rule type is not available whcih is wierd. Further more it appears that Test suites only allows to add test cases which are instance of RULE-AUTOTEST-CASE class but Data Page test cases are of instance of RULE-TEST-UNIT-CASE class. I can imagine that this could be due to ongoing feature enahcenment of exsiting Unit test case framework.
Is there any other rule type already added in Pega v7.2 to create test suites for Data Pages or a patch fix to this issue is yet to come?
This comment has been branched out as a new node and the new thread can be followed here
Please check below link may be useful.
https://community.pega.com/support/support-articles/error-while-loading-test-case-and-test-suite
