Testing activity from Test Suite fails
Hi, I have a test case which passes when run on its own. However, when run from the Test Suite, it fails. With all settings enabled on the tracer, it is impossible to see what context the suite runs the particular test case or any rules used in that test case, so I cannot debug this. Is there a workaround on how I could identify what is causing the problem?
The test case is for an activity, which calls Data Transform. There is a ServicePage defined as a step page for the step that uses Apply Data Transform method. This step is of int class. When run from Test Suite a message on a failed test case is returned as unable to find Data Transform in Work class. ServicePage is defined in Pages and Classes tab.
Any help would be appreciated.
