SYSTEM ARCHITECT ESSENTIALS PEGA 8
Hi Team,
For the Course for Infinity 8 is not working for VM Player attached screen shot.
Please fix so that we can work.
Hi Team,
can someone please comment if they are also getting the same error.
Did you change the file extension to .ovf before downloading? I had the same error when i forgot to do this in the download popup window ...
On click on the download link the Download is the zip file, are you saying should I need to save the zip file in .ovf format
yes correct as per the download instructions in the pdf on the course environment, depending on the browser your using there are some different things to keep in mind. They are all listed in the exercise environment pdf
regards,
Leo
http://pegasystems2.http.internapcdn.net/pegasystems2/exercise_guides/Pega_Academy_Virtual_Machine_User_Guide.pdf check out the part on downloading the exercise environment.
regards,
Leo
