System Architect Essentials - Final Solution Build Exercise
I am attempting SAE8 Solution build and I get thrown the error below, any ideas?
Show More
Error trying to process
R-7
Action that failed
HarnessFail
For class
Tour-CarRentals-Work-RentalReservation
Current operator
author@tourist
In Flow
AuthenticateExistingCustomer
At step
Assignment1
Object key
Read/Write
0
Harness class
Rule-HTML-Harness
Frame name
pyWorkPage
Error message
Section 'Perform' execution error on page 'pyWorkPage' of class 'Tour-CarRentals-Work-RentalReservation'. : Component stack mismatch {"pyCell":{"liveUI":"data-ui-meta=\"{'type':'Cell','subType':'pxTextInput','clipboardPath':'.FirstName','className':'Tour-CarRentals-Work-RentalReservation','pgRef':'.pyRegions(1).pyCells(1)'}\"","pyLabelReserveSpace":"true","partialClass":"remove-left-spacing flex","automationId":"'2019061909183806027983e371-ffcf-4ee1-af16-2c3bd659750f152-Label'","format":"pxTextInput","forLabel":".FirstName","pyAutoHTML":"true","spanClass":"iconRequired standard_iconRequired","cstmreqfor":"pyRequired","pyReadOnlyWhenCond":"readonlyAlways","labelJSP":"false","pyLabelValue":"First Name"},"pyName":"DynamicLayoutCell"}!!!!===={"scrollClass":"","centerInspectorData":"data-ui-meta=\"{'type':'Panel','subType':'CENTER'}\"","ariaLabelCenterPanel":"Center Panel","startWrapperDiv":"true","endWrapperDiv":"false","pyName":"pxWorkAreaContent","pyTemplates":[{"pxReferencedId":"f1d9f0e7b55568cc467ef833b061d4cc1a5145b2_6","pyName":"pxSection"}]}
Show Less
