T?rkiye Finans Katilim Bankasi
Last activity: 10 May 2019 8:18 EDT
Step Name Localization Problem
I didn't translate my case's step names. We imported translation document and checked the field value, they were saved as "pyCaption". But Pega didn't show translated values.
Are there any solution or hotfix?
Updated: 10 May 2019 8:17 EDT
Hi Ahmet,
Thank you for posting your query in Pega Support Community!
Could you please confirm the version of Pega that you are using?
Geeda.
My prpc version is 7.1.7
Hi Ahmet,
As an extension to the above information, the same behavior is reported in 7.1.6 and it is fixed through hotfix. If you are using 7.1.6 then SA-24019 might help you.
If you are using Pega Platform 7.3 then SA-42533 might help you to address the reported behavior.
Geeda.
I installed HFIX-52926 which is suitable version of HFix-27864. Bu tproblem not resolved
Hi Ahmet,
As part of HFIX-52926, Resaving of case type from designer studio and re-running the localization wizard is required. Before this do a restart of server by clearing Pega temp directory and browser cache.
Please make sure that you have followed the guidelines to install the HFIX-52926. If you could find the issue after performing the above mentioned steps, please share the logs to analyse further.
Geeda.
I completed all steps after hotfix installation. As you can see screenshot. system save my translation value to @baseclass as pyCaption. but system not show the translation values.
I resolved my problem with HFIX-53150 and HFIX-52926.
