Sort not working for while displaying in Table
I am passing Report Definition as source for a Table in section (Screenshot_1). I am facing 2 issues there:
1. I want to limit the number of records displayed as 30 but it is not working with the option 'Maximum number of rows to retrieve' available in Data Access tab of RD. If I execute the RD, I can see that it is displaying only 30 records but in Table it displays the whole records in the system.
2. So I am restricting it as mentioned in Screenshot_2 but the sorting doesn’t work in table with this change.
Can anyone please help to resolve this as soon as possible. PRPC version : 7.3.1
Do you have paging on in your grid? If so, please disable it. Also revert the change to limit the number of results in the report definition (screenshot 2). Set the "Maximum number of rows to retrieve" to 30 as you had originally done (on the "Data Access" tab). This should display 30 rows in the grid, with sorting still enabled.
When paging is enabled on the grid, I believe that the value set for "Maximum number of rows to retrieve" is ignored.
