Accenture Solution Pvt Ltd
Last activity: 2 Nov 2017 8:01 EDT
SnapStart url with AES encrypted parameters
We have to create a case in Pega via a SnapStart URL. Now client is sending some parameter with AES encrypted. Would you please let me know
1. How to create a case via SnapStart URL.
2. How to decrypt the parameter values in Pega.
We are using Pega 7.1.9
Its little old document but I believe this should work. I didn't find any new document.
https://community.pega.com/how-create-snapstart-urls-desktop-integration
Thank You.
If we follow the approach which is mentioned in the link you provided then we can't open the flow in the Portal. It's opening in a Harness. So below link is helpful
However, would you please let me know how to handle point 2 i.e decrypt the incoming parameters.
I asked one of our SME he suggested to use crypto libraries for this.
Thank You
I didn't find any crypto library.
However there are functions like Utilities • decryptPropertyValue where I can see pega used "tools.getPRCrypto().decryptPropertyValue(property.getStringValue()" to decrypt. But i guess this is base-64 decoding.
If I need to use a different decryption logic like AES (Advanced Encryption Standard) then what is the process. Do I need to upload any jar file and need to write specific function.
I can see Platform cipher uses AES-256, you can check that
Thank You.
We are using pega 7.1.9 and above help is for pega 7.3.1 . Landing pages which are mentioned there are not available in Pega 7.1.9
You don't need to upload any jar, it will be supported by JDK.
I am not sure how pega 7.19 implementation will be taken care of.
Thank You.
