SLA deadline questions
The inheritance path for an application contains four copies of the pyDefault data transformation
that set property values for two properties: Work item Urgency and Prefix.
| Class | Work Item Urgency | Prefix |
| Inscorp-ClaimAdm- Work- AutoClaim | 25 | [no value] |
| Inscorp-ClaimAdm- Work | 20 | "C-" |
| Work | [no value] | "W-" |
| @baseclass | 10 | "O-" |
If the Call data transforms in superclass option is enabled for each data transform, what are the
values of Work Item Urgency and Prefix use crates an auto claim case?
A. Work Item Urgency =25, prefix = [no value]
B. Work Item Urgency =20, prefix =C-.
C. Work Item Urgency =10, prefix = O-.
D. Work Item Urgency = 25, prefix = C-:
I believe D is the answer. Can some on confirm and if different please explain ?
A user view includes a list of four urgency options selectable by radio buttons. How do you configure
the selection list?
A. Configure a field group with selectable urgency options.
B. Configure a drop down field with selectable urgency options.
C. Configure a picklist with radio buttons for the urgency options.
D. Configure a Boolean field with selectable urgency options.
the selection list?
C seems to be the right answer (Picklist with radio buttons)
