Sketch library for SCE Framework (UIKit 14.01)
Hi – I'm a UI designer new to PEGA. Our dev team is working with the UIKit 14.01 that came with the product (Healthcare Codes Management Application) that's used by the SCE Framework. I'm looking for a Sketch Iibrary specific to this framework. I found the legacy Sketch library to download, but noticed that the library seems to have a different look and feel than our team's test environment. The dev team has made no customizations. The Sketch library I downloaded has more of a blue-gray look and feel, whereas the work in dev have a more modern, cleaner, blue and white look. Anyone know if there's a different Sketch UI library specifically for SCE Framework? Also, the dev team called out that they are NOT using Cosmos.
