Techmahindra
Last activity: 17 Apr 2018 2:55 EDT
Setting Maximum Email Size for Inbound Email
we have four listeners in our application. So, we thought of using DSS which will be applicable for all Email listeners
Option 1: We tried and it is not working
Owning rule-set : Pega-IntSvcs
Purpose: Services/EmailMaxSize
Option 2: We tried and it is not working
Owning rule-set: Pega-Engine
Purpose: prconfig/services/emailMaxSize/default
Can someone suggest, how to set DSS?
Thanks in Advance..........
Hello Rajsekhar,
As per this article below DSS should work
However if your observing it’s not working please enable debug for the logger EmailListener and let us provide the logs for review .
Arun
Techmahindra
Hi Arun,
We have tried DSS, it is not working
Do we need to restart the server?
Yes restart the server once .
Arun
Hello Rajasekhar,
Can you please check if you have given any value to the Maximum Email Size (KB) field on the process tab of the email listeners form?
I am asking this because a value entered in this field overrides the value specified in the configuration setting prconfig/services/emailMaxSize/default.
Thanks!
Techmahindra
Thanks, we have not given any value to the Maximum Email Size (KB) field on the process tab of the email listeners form.
Did you try restarting the listener
Techmahindra
I am setting the DSS. Do we need to restart the Server for setting DSS?
Hi Rajasekhar,
Please refer this link troubleshooting email related issue in Pega.
https://collaborate.pega.com/discussion/troubleshooting-common-email-issues
There are chances when your EmailMaxSize is getting configured but it's failing due to other issues.
Techmahindra
Can someone reply to above query..........
Hello Rajasekhar,
My colleague Arun replied on Jan 1 saying, restart is required after setting the DSS.
Please try that and check whether the issue is resolved, otherwise please share us the logs for review.
Thanks & Regards,
Durga
Techmahindra
Thanks Durga for your reply. We will check after restart of server.
Query: We have set "email/fetchsize" DSS and not restarted. Can we find some place in PDN to get the list of DSS required Server restart.
Techmahindra
Techmahindra
Techmahindra
Techmahindra
Techmahindra
