Separate rulesets for each integrations?
Had few questions for you guys. Need architectural recommendation.
When it comes to connecting to external APIs (e.g. REST, SOAP, JMS) that our Pega Application plan to consume:
- Does Pega recommend creating separate rulesets for each integrations?
Show More
- Does Pega recommend creating separate rulesets for each integrations? Or, use a single rulset that will contain Integration rules/components from many different interfaces?
- What are the pros and cons?
- What is the impact on rule resolution and performance?
- What if the number of interfaces/Integrations is high (e.g. 50)?
- What is the highest number of rulesets that you recommend to use in Application Stack?
Niaz
Show Less
