NTTDATA Getronics
JP
Last activity: 23 Nov 2017 9:05 EST
SendKeys does not work on Windows Screen Saver
I want to save the screen of IE on PDF by using Sendkeys.
Sendkeys is "File (F)" → "Print (P)".
The Sendkeys can be realized by using C# scripts.
Normally, the Sendkeys works without problems,
but when Windows becomes a screen saver,
The Sendkeys does not work.
Since screen savering is required as a security requirement,
I am looking for solution of this isuue.
Possibly, but that would be done using C#. I would suggest looking in CodeProject or other C# specific forums for C# questions though as you will find more options there. Keep in-mind that while Pega Robotics does not care if your system is locked, your applications may. Since Pega Robotics is designed to automate user-actions as a user would, and since you currently don't have users performing these tasks while there systems are locked, you likely do not know if the applications behave differently. Some applications (like Internet Explorer for example) know when the system is locked and behave differently; often leaving off controls they would normally display.
