Sending Special character included string as a parameter issue
I have an issue when sending parameters to Open URL in Window. I need to pass a special character-included string as a parameter in action to an Activity.
Parameter value = "おざわ038検証用ファイルファイルゐゑxlsx.!$(),;{}#%&+@^`~_=-"
It gives 400 request error. Is there any way to pass this value as a parameter to activity?
@Ashan
When passing parameters containing special characters as a parameter in an Open URL action in PEGA, you need to make sure that the parameter is URL encoded. URL encoding is a way to convert special characters into a format that can be safely transmitted over the internet.
To encode the parameter value, you can use the
encodeURIComponent()JavaScript function. This function encodes all characters except for the following: alphabetic, decimal digits, - _ . ! ~ * ' ( ) .Here's an example of how you can encode the parameter value in a PEGA Open URL action:
http://localhost:8080/myApp/myActivity?param1=<param1Value>encodeURIComponent()function. For example:var param1Value = encodeURIComponent("おざわ038検証用ファイルファイルゐゑxlsx.!$(),;{}#%&+@^~_=-");`http://localhost:8080/myApp/myActivity?param1=+ param1ValueBy encoding the parameter value in this way, you should be able to pass the special character-included string as a parameter to your Activity without encountering a 400 request error.
