Selenium Automation configuration to test the PEGA Workflows
We are currently using Selemium for the Automation test cases of PEGA Workflows. Currently its all working fine with PEGA 8.4.3 and after the PEGA upgrade of 8.8.3, lot of places it had the issue with the XPath changes.
Just want to understand what's the recommended approach for the selemium scripts to identify each element in the UI ?
Do we need to use TestID which is present at each field ?
