Scrolling carousel on Portal
How can I create scrolling carousel on end user portal. My application is based on Pega V 6.2.Please kindly share your suggestions.
Can anyone please help?
Hi ,
Have you checked with the https://www.w3schools.com/w3css/w3css_slideshow.asp.
In a non auto generated section you can keep the code and give a try.
You need to put the images in the webwb folder and give the correct path to them.
Hi Sir,
I tried to implement the same thing stated as above but, its not showing image.Even after I created the binary file for image and gave the directory path image is not shown can you please explain me via, Scrrenshots or dumps that would be really helpful.
