SAML WebSSO SHA1 issue with ADFS
I am trying to configure Desktop SSO between Pega(SP) and ADFS(IDP) but getting the following error:
Unable to process the SAML WebSSO request : The Response did not contain any Authentication Statement that matched the Subject Confirmation criteria
I can see in the logs that the SAML Web SSO Authentication Activity (Step: AuthService.pySAMLWebSSO) is generating a SAML request with a SHA1 signature:
Generated authentication request : <saml2p:AuthnRequest....<ds:SignatureMethod Algorithm="http://www.w3.org/2000/09/xmldsig#rsa-sha1"/>
But ADFS is generating a SHA256 signature method response.
Is there any way to configure Pega such that it uses a "http://www.w3.org/2001/04/xmldsig-more#rsa-sha256" signature method algorithm?
The method samlutils.createAuthenticationRequest passes in a Data-Admin-Security-SSO-SAML class type, but there is no property to set the signature method algorithm.
Bill
***Updated by moderator: Lochan to tag SR to post***
Upon reviewing the associated SR, SA-55228 was generated as the resolution.
If you have the same question, please check out "ADFS does not recognize Pega SAML request signature" to resolve this for you.
