RunTime Error on PropertyValueInvalid (Invalid number format pegaToBigDecimal)
Is there OOTB function that I can use to determine Invalid number format ? I have a web form where a user is entering an invalid data type (for example :- user enters alphabet characters instead of numeric characters).
PEGA throws an 'is not a valid decimal value'
but I also get a run time error because I am doing a PostValue and running a DT of the posted value.
On the onChange event of this property I have a PostValue and a refresh of this section with a data transform that uses this entered property. As the invalid property is posted, the data transform that fires is picking up the wrong data type posted value and I am getting a run time error.
I see the following exceptions in the Tracer .pegaToBigDecimal() Invalid number format
Is there any Pega function that I can use on the Change event to determine if a VALID datatype is entered BEFORE I execute the Post value? I was not able to find pegaToBigDecimal() or Invalidnumberformat() or any OOTB functions.
I would like to check for a valid value before I do the PostValue and/or run the DataTransform? Any input from you would be appreciated.
