Ford Motors
Last activity: 7 Jun 2018 15:26 EDT
Running a case gets failed
I have created a case and it worked successfully till yesterday,but while am running the case today it gets failed and unable to find the solution for that.
Can anyone help me out with this problem??
Ford Motors
I didn't passed the step page in the activity at first.
Then when i entered the step page in activity it started working properly.
Thanks!
ManikantanJ
PEG
What kind of error does this display to the user?
And do you also see errors appearing in the logs?
If not (and possibly if so) can you see anything in tracer which gives any indication of an underlying problem (please ensure the "Exception" event is enabled)
Ford Motors
Its working fine..
Thank you..
Jose Navas SRI RAMA KRISHNA CHAITANYA VEDALA RamPrakash Avasarala Giulia Celeste
EPAM Systems, Inc.
ES
Were there any changes made in the environment since then?
Is there any developer checked in new code, you could verify it by navigating. (Design Studio->Application->Development->Developer Activity).
To start the investigation, could you share the screen-shot of the error appearing. Also, share the PegaRULES log files capturing the event. Also, we would need to tracer capturing the use-case with tracer setting "Stream rules" checked.
Ford Motors
Its working fine ..
Thank you @Asif_Hasan
EPAM Systems, Inc.
ES
You're welcome. Could you share the reason why it was happening, for larger Pega audience?
Ford Motors
The activity which i was created is not working properly for invoking the connector so i fixed it then it started to work properly.
Hey @ManikantanJ!
Could you share what you did to fix this? That will help other Community members who may have the same question later.
Thanks!
Ford Motors
Thanks!
ManikantanJ
