Run this agent on only one node at a time, is my config correct?
We have a cluster and all our agents/file listeners and MDB listeners are mapped to this cluster because they are started as DNodeType=BackgroundProcessingNode.
Only we have some agents that only should run on one node only. I have enabled the option "Run this agent on only one node at a time", but when I check the agent list in the SMA I still see this agent running on all the nodes that are started as DNodeType=BackgroundProcessingNode.
Can anyone tell me if this is correct?
