Routing object
In Routing activity what is the default property used to route the object?
If you are talking about pzUpdateRouting activity which is called from the selection of Route to operator in Case Step General settings, pyRouteTo is the property used.
If you are not looking for this information then kindly elaborate your use case requirement.
Regards
Mahesh
