Inovar
SA
Robotic Work Queue
Can you help me in how to route assignments to robot work queue by using robot queue shape.
Can you tell me how to configure it in the flow and route that assignment to it.
Can you provide me detailed steps.
Add a robotic assignment to your Flow Action.
It is found on the Advanced Shapes menu.
You need to set the WorkBasket and the Robotic_Automation name as well.
Inovar
SA
HI Jeff,
I have configured the robotic assignment as part of RPA to create new contact.
But i am getting the error assignment not found for the given operator id.
Attached the screenshot for your reference.
Could you please let me know what is the problem here.
Can you share a little more information? You may want to open a SR to have someone look at the whole project.
Hi Gopi,
Please let us know if you do log an SR for this and its ID. That way we can track it and follow-up this discussion with the resolution.
Thank you!
Inovar
SA
Hi Lochan,
I have raised an SR for this . Currently it's in progress.you have already associated the SR number with that post in PDN.
Gopi
Thanks Gopi,
Do you mean the SR tagged in this post? RPA process
Are both the questions being handled on the same SR?
Thanks!
Virtusa Corporation
Hi Lochan,
I am also facing similar problem with Robot Queue. My Robot picking case from the Robot Queue and processing it, But my case is not procedding to next assignment in the flow. have you find any solution for your issue.
Thank you in advance.
Hi Mani,
I took a look into SR-B40103 which was created by Gopi. I see that the SR is in progress.
Inovar
SA
Hi lochan, we did this in pega 7.2.2 version. its resolved this issue.
Hi Gopi,
Glad to hear that it was resolved :) Thank you for the update.
