REST service is not receiving input data
I have a REST service that implements GET and PUT. The PUT function works fine; it takes a page property of data in the Message Parameters area, inserts the data into a data type and returns "Data added successfully". The GET does NOT work - it takes one property in the Query string area; I have confirmed by writing a log message from the service activity that no value is being received. I am using Map to Clipboard to process the input on the service and the service activity relies on the primary page to access the property. The service and connector are on the same cloud instance, except that they are built in different parent class structures (service is in MyCo-xx and connector is in ABC-xx).
