Required fields in modal
Hello
I have a table with edit settings in a modal window
On the section in the modal window there are several required fields.
The problem is that if you do not click on the required fields and do not fill them out, then when you click "Submit" in the modal window, the required fields remain empty and the record is saved without them.
Button settings can also be found in the attached picture.
