Swedbank
SE
Last activity: 15 Jun 2020 2:56 EDT
Report definition is sending a null value when replace function is used
Hi!
My report definition must fetch the information based on the person number and the format of the person number can be YYYYMMDD-NNNN or YYYYMMDDNNNN.
In the report definition am using replace function to replace "-" with empty space like "" and the string changes to YYYYMMDDNNNN. But when am not passing any string through the report definition the SQL query is generates as:
select * from tablename WHERE ( ( "CustomerInfo"."PERSONALNUMBER" = REPLACE(? ,? ,'') ) ).
The question is there’s any possibility in pega report definition to not send a "null” when the string is not passed. In my case I want the SQL query as:
select * from tablename.
***Edited by Moderator Kayla to update Platform Capability tags****
In RD filter configuration do you have Use null if empty checked?
