Remove entries from Add widgets to slot - Dashboard
I created a new section, of type ‘Dashboard widget’, which I can select from the Portal Dashboard ‘Add widgets to slot’ dialog, under the ‘Reporting’ category.
I accidentally created 2 other sections, with the type ‘Dashboard widget’, but these should be a standard section.
Even though I’ve changed these to a standard section, they still appear in the Add widgets to slot’ dialog.
How can I remove these erroneous entries?
I have tried logging off/on to Pega and clearing browser cache/files.
