Cognizant Technology Solutions India Ltd.
ES
Last activity: 28 Aug 2019 10:32 EDT
Reference Division layer rule in a Framework layer rule
Hi ,
A question regarding extending the rules defined in FW layer data type in implementation layer.
Scenario:
If a application is builton a FW application and in the case a page type property is defined of class ABC-FW-XYZ-Data-Event , to show data from this page a section is also defined at the same class. Now the section uses a data page which is defined in Divion layer (ABC-Div-Int-Service) which is part of implementation application. How to specialize the section defined ABC-FW-XYZ-Data-Event to use divison layer rules?
Options :
- Save as the same section to implemetation ruleset but the class remains FW ? It doesn't sound good to me but is it recommended? If it recommended also the error is still there because the FW class can't reference a Div layer rule.
