Re-using a test-case for multiple rules
Is there any way by which we can test multiple when rules, which are similar ( similar in the sense that they check the same single property ) using a single test case, rather than create multiple copies of the same test-case for each when rule? What I want as an end result, is to have the same test case appear in the "Test Cases" tab of each of my when rule, without creating copies of the same test case for each of them.
Thanks in advance!
I don't think you can do this currently. It is always associated to a specific rule.
