Test Case for a When rule
Hi
I need advice on how Test Cases for a When rule work.
My expectation was that while Test Case is created from a Run window of the When rule, it would receive the supplied context (clipboard page or data transform), so the the newly created Test Case will run with the same input. The setup for the test case would be automatically configured, just like it happens with decision strategies. But in reality, from what I see, Test Case is created with no context, no setup, and I cannot even supply the context manually. It is not clear which page is test case using for the run. I have tried RunRecordPrimaryPage and pyWorkPage but it seems like the Test Case for When rule is ignoring any input I provide.
The only way I can make test cases for When rules work is by supplying Multiple Input Combinations, which is sometimes OK, but only if a When rule is referencing properties directly. If When rule is invoking another function this approach will not work.
I have found very similar question in this forum but with no answer - https://collaborate.pega.com/question/when-rule-parameters-failing-unittest
May someone advise please what is the suggested approach when creating Test Cases for When rules
Thanks and Regards
Andy
***Edited by Moderator: Pallavi to change category from General to Product, update platform capability tags***
Solution is this - you need to supply a Data Transform in Setup section of the Test Case.
But then this Data Transform need to instantiate and refer to a page named RunRecordPrimaryPage. So that inside DT you assign values to RunRecordPrimaryPage.something.something
Quite straight forward actually, but it took me a while to figure out
