Verizon Data Services
Radio button action is not firing in table(grid) in 7.3
I have a table(pega version 7.3) previously repeat grid the source of which is a page list property . In the first column of the grid , I have radio button control , on change of which I am posting the value . The issue here is ,when I select the radio button for the first row in the grid , it is firing the reload cell event(post action) , but if I select any other row , it is not posting the value for that row and not resetting the value for first row also.I can see in the ui that second row has been selected and first one unchecked . Finally when I submit the form , I have both the rows selected in the clipboard.
Likes (1)
Varun Chandana -
As per pega the behavior is expected i.e. onChange action in Radio Button won't work inside a repeat grid.
Which control you are using and also which property you are mapping the radio button with /
pxRadioButton and a boolean property .
Techmahindra
Hello Nikhil,
You can find many post regarding onclick event on a radio button in a grid layout not being triggered the reason behind this is radio button does not support onclick events. In many cases we have advised to use custom code or a check box which is meant for such click events.
However incase if your using any control as pzGridRadioButton then please share the screen shots of your configuration.
Shanthini Charles
Mohammed Adil Saleem
I tried using pzGridRadioButton control as well but it's not working . When I source the table with a page group property then pzGridRadioButton is working fine but with page list property it's not working .
J.P. Morgan Services India PVT Ltd
what is the behavior if you are changing the source of the grid? Also I am not clear with the action set you are giving on the cell. can you attach some screenshots for that.
Are you noticing that the values are not correctly selected when you click on the radio button in a grid ? Are you clicking on the label or the control itself ?
IS the issue you reported similar to what is mentioned here ?
https://community.pega.com/support/support-articles/same-id-generated-radio-button-checkbox-elements
Dulshanka De Silva
Express Scripts
Hi Nihil,
i have similar kind of issue in pega 7.22. inside table grid radio button actions are not working.
so i got hotfix, but after that im not able to see radio button in Windows 10 IE 11.
but reaming all browsers it is working fine.
Please refer this SR: SR-C24081 (DL-85010 Contents of this package are:
PARENT HOTFIX: HFIX-43398
DEPENDENT HOTFIX(ES):[HFIX-32252] )
Hi Rajesh,
As per pega radio button events will not trigger properly inside a grid and it is expected behavior. If you received the hotfix then you can inspect the html code and see what is not letting the radio button render properly in IE 11 . If you are unable to find the root cause then you can go back to pega and they will give you the fix for IE as well.
The simple solution is using a check box inside the grid.
