Question on setting default value
Please help with the right answer to below:
If you want to set default value in the UI where will you set
- Control
- Property
- Data transform py default
- Non of the above
in some mock test its says "Control" and in other it says "Data transform py default"
Please advise which is the right answer.
Thanks.
