CITI
CN
Last activity: 17 May 2023 2:02 EDT
Question on Low-Code App Builder exercise: US-002: Configure the Create view
In this exercise, the US requirement is as below showing:
US-002 DescriptionConfigure the Create step with a data reference field named Balance transfer account that is a single record and is sourced from the preconfigured Account data object. The view should display the following fields, which are already defined for the data object:
Configure the data reference field as an Autocomplete field that displays the account number field. |
But when I start to edit the view for the Create step (Configure view->ADD->Fields->...) , I cannot find the required field or data object name. Could you pls advise how to find the required field name under the Configure view function?
