TCS
Last activity: 19 Dec 2016 5:39 EST
Query on Feasible Automation Tools for OpenSpan
***Moderator Edit: Vidyaranjan | Updated Categories | Tagged Srexists ***
You can use the built in Unit Test functionality. Here are some links that will help you get started.
http://help.openspan.com/80/Components/Unit_Testing_-_Overview.htm
http://help.openspan.com/80/Components/Unit_Test__Automations.htm
http://help.openspan.com/80/Components/Test_Runner_Console_Application.htm
TCS
Hi Jeff,
Thanks for the information. We will go through these links and check if they can help us.
Regards, Viji
TCS
Hi Jeff,
From the links you provided, we understand that these are the options for the developers performing Unit Testing. Please let us know if we have similar techniques for the Testers to perform SIT & Regression Testing.
Thanks, Viji
The unit test feature allows you to build unit test automations. Those must be built by the developers, however using TestRunner they can be run by your testers or run automatically. Once you have unit test automations you can use them for SIT & regression testing throughout the life of your project.
The issue that is most commonly encountered however, is maintaining the test data in disparate systems to support your unit tests. Keeping data in a certain state in one application is usually possible but maintaining that state across multiple applications may be difficult. Therefore, unit test your application at the smallest level possible and do not try to do fully automated SIT testing.
TCS
Hi Jeff,
Thanks for the suggestions. We will give it a try and keep you posted on the updates.
Regards, Viji
TCS
Hi Jeff,
Please provide your email address/contact number so that we can call you to understand the automation feasibility for OpenSpan with respect to SIT and UAT.
Thanks, Viji
Hi Vijayalakshmik1467,
Great conversation here with Jeff! At this time, it would be best for you to contact the Account Executive on your account. They will be able to help you with your question above.
Thanks in advance!
Marissa | Community Moderator | Pegasystems Inc.
Updated: 19 Dec 2016 5:15 EST
TCS
Thanks Marissa. We had already mailed to our Account Executive regarding this query. No replies yet. Please confirm the email ID
<edited by Moderator: Lochan to remove personal information>
Hi Viji,
I have sent you a PDN private message with some details that might help!
Lochan  |  Community Moderator  |  Pegasystems Inc.
