pyFTSIncrementatlIndexer cannot be started as it is in '-' state error
Please help to resolve the error encountered in Pega Queue processor rule.
Pega Framework version: Pega 8.1.3
Show More
2019-06-17 00:39:25,005 [CHEDULER_THREAD_POOL] [ STANDARD] [ ] [ ] (ndexer.DistributedIndexerAgent) ERROR - Exception while performing queue processor management operation
com.pega.pegarules.pub.context.QueueProcessorManagementOperationsException: Queue processor: pyFTSIncrementalIndexer cannot be started as it is in '-' state
at com.pega.platform.executor.queueprocessor.internal.QueueProcessorManagementOperationsImpl.startQueueProcessor(QueueProcessorManagementOperationsImpl.java:682) ~[pega-executor.jar:?]
at com.pega.pegarules.management.internal.system.operations.QueueProcessorManagementAPI.startQueueProcessor(QueueProcessorManagementAPI.java:73) ~[prprivate.jar:?]
at com.pega.platform.pegasearch.indexer.internal.DistributedIndexerAgent.manageIncrementalIndexer(DistributedIndexerAgent.java:168) ~[pegasearch.jar:?]
at com.pega.pegarules.session.internal.mgmt.Executable.manageIncrementalIndexer(Executable.java:11380) ~[prprivate.jar:?]
at com.pegarules.generated.activity.ra_action_pzmanageincrementalindexer_921cf20315b934ab9b56a5fa027e14bf.step1_circum0(ra_action_pzmanageincrementalindexer_921cf20315b934ab9b56a5fa027e14bf.java:161) ~[?:?]
at com.pegarules.generated.activity.ra_action_pzmanageincrementalindexer_921cf20315b934ab9b56a5fa027e14bf.perform(ra_action_pzmanageincrementalindexer_921cf20315b934ab9b56a5fa027e14bf.java:70) ~[?:?]
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3556) ~[prprivate.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityExecutor.runActivity(ActivityExecutor.java:33) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityExecutor.executeActivity(ActivityExecutor.java:25) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.execute(ActivityProcessor.java:55) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.run(ActivityProcessor.java:108) ~[pega-executor.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1366) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1109) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:990) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImplForModules.doWithRequestorLocked(PRSessionProviderImplForModules.java:55) ~[prprivate.jar:?]
at com.pega.platform.executor.jobscheduler.internal.JobSchedulerProcessor.execute(JobSchedulerProcessor.java:48) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.scheduler.internal.JobRunTimeImpl.execute(JobRunTimeImpl.java:67) ~[executor.jar:?]
at com.pega.platform.executor.jobscheduler.scheduler.internal.JobRunTimeDecorator.execute(JobRunTimeDecorator.java:57) ~[executor.jar:?]
at com.pega.platform.executor.jobscheduler.scheduler.internal.JobExecutionTemplate.executeJob(JobExecutionTemplate.java:45) ~[executor.jar:?]
at com.pega.platform.executor.jobscheduler.scheduler.internal.JobExecutionTemplate.run(JobExecutionTemplate.java:35) ~[executor.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_152]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_152]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_152]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:1.8.0_152]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_152]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_152]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_152]
Appreciate if you could response ASAP as this is one of the causes why our DEV server becoming slow as this has been happened consecutively. Thank you!
Show Less
Hi ,
Pega 8.x requires at least one stream node (or a universal node).
Could you please check if you added stream node in Decisioning-->Infrastracture-->Services-->Stream path and if the node is up and running?
Waseem Khan
