pyCaseManager7 portal deprecated in Pega 8.1.0
Pega 8.1.0 includes the pyCaseManager7 portal but the rule is now marked as deprecated and the Description/Usage on the History tab include no documentation on what to use instead. The only other portal that appears to be a possible replacement is the pyCaseWorker. Is the pyCaseWorker portal what we should be updating our Access Groups to use?
Note: It would be really helpful if Pega noted in the Usage field on the History tab what the recommended replacement is for any rule that has been deprecated.
Now all UI related rules are available from UI kit. Please check for siblings for UI Kit rules.
