Cigna Corporation
Cigna Corporation
Cigna Corporation
Posted: Oct 12, 2022
Last activity: Oct 18, 2022
Last activity: 18 Oct 2022 1:53 EDT
Purging maintenance tables
We have a pega 8.5.6 installation at Cigna and the two largest tables in the database are :
PR_PERF_STATS - 117 million rows
PR_DATA_SVCINVHIST - 105 million rows
Is it ok to truncate these tables ?
@TimothyK8255 you logged your question under Pega Robotic Automation tag. Can you confirm this is for Pega Platform only?
There are some questions on the forum where this topic was raised before: Do we need to consider PR_PERF_STATS for Reorg Job at DB side?
Also see Node and cluster default job schedulers
Did you check the available documentation under Trimming the pr_perf_stats table - does this answer your question?
