Fastweb SPA
IT
Last activity: 18 Oct 2022 14:03 EDT
problem starting jboss on pega server
Hi, we have a problem starting the 3th instance of JBOSS on application server PEGA, the error ocurred is :
19:06:44,487 WARNING [com.hazelcast.spi.impl.BasicInvocation] (hz._hzInstance_1_668e03f97c14a138d2c4267ce8ce03b2.response) [xx.xx.xx.xxx]:5702 [668e03f97c14a138d2c4267ce8ce03b2] [3.2] Retrying invocation: BasicInvocation{ serviceName='hz:impl:mapService', op=com.hazelcast.map.operation.MapKeySetOperation@7c9fb2eb, partitionId=130, replicaIndex=0, tryCount=250, tryPauseMillis=500, invokeCount=240, callTimeout=60000, target=Address[xx.xx.xx.xxx]:5701}, Reason: com.hazelcast.spi.exception.PartitionMigrating
Exception: Partition is migrating! this:Address[xx.xx.xx.xxx]:5701, partitionId: 130, operation: com.hazelcast.map.operation.MapKeySetOperation, service: hz:impl:mapService
19:06:49,531 STDERR [stderr] (asxxxxxx.intranet.fw) com.hazelcast.spi.exception.PartitionMigratingException: Partition is migrating! this:Address[xx.xx.xx.xxx]:5701, partitionId: 130, operation: com.hazelcast.map.operation.MapKeySetOperation, service: hz:impl:mapService
19:06:49,531 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.spi.impl.BasicOperationService.processOperation(BasicOperationService.java:344)
19:06:49,531 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.spi.impl.BasicOperationService.processPacket(BasicOperationService.java:309)
19:06:49,532 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.spi.impl.BasicOperationService.access$400(BasicOperationService.java:102)
19:06:49,532 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.spi.impl.BasicOperationService$BasicOperationProcessorImpl.process(BasicOperationService.java:756)
19:06:49,532 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.spi.impl.BasicOperationScheduler$PartitionThread.process(BasicOperationScheduler.java:276)
19:06:49,532 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.spi.impl.BasicOperationScheduler$PartitionThread.doRun(BasicOperationScheduler.java:270)
19:06:49,533 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.spi.impl.BasicOperationScheduler$PartitionThread.run(BasicOperationScheduler.java:245)
19:06:49,533 STDERR [stderr] (asxxxxxx.intranet.fw) at ------ End remote and begin local stack-trace ------.(Unknown Source)
19:06:49,533 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.spi.impl.BasicInvocation$InvocationFuture.resolveResponse(BasicInvocation.java:836)
19:06:49,534 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.spi.impl.BasicInvocation$InvocationFuture.resolveResponseOrThrowException(BasicInvocation.java:769)
19:06:49,534 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.spi.impl.BasicInvocation$InvocationFuture.get(BasicInvocation.java:696)
19:06:49,534 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.spi.impl.BasicInvocation$InvocationFuture.get(BasicInvocation.java:674)
19:06:49,534 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.spi.impl.BasicOperationService.invokeOnPartitions(BasicOperationService.java:613)
19:06:49,535 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.spi.impl.BasicOperationService.invokeOnAllPartitions(BasicOperationService.java:549)
19:06:49,535 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.map.proxy.MapProxySupport.keySetInternal(MapProxySupport.java:573)
19:06:49,535 STDERR [stderr] (asxxxxxx.intranet.fw) at com.hazelcast.map.proxy.MapProxyImpl.keySet(MapProxyImpl.java:479)
19:06:49,535 STDERR [stderr] (asxxxxxx.intranet.fw) at com.pega.pegarules.cluster.internal.PRClusterHazelcastImpl.checkMembershipConsistency(PRClusterHazelcastImpl.java:418)
19:06:49,536 STDERR [stderr] (asxxxxxx.intranet.fw) at com.pega.pegarules.session.internal.mgmt.PRNodeImpl.checkClusterConsistency(PRNodeImpl.java:2397)
19:06:49,536 STDERR [stderr] (asxxxxxx.intranet.fw) at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:374)
19:06:49,536 STDERR [stderr] (asxxxxxx.intranet.fw) at com.pega.pegarules.session.internal.PRSessionProviderImpl.getThreadAndInitialize(PRSessionProviderImpl.java:1905)
19:06:49,536 STDERR [stderr] (asxxxxxx.intranet.fw) at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:657)
19:06:49,537 STDERR [stderr] (asxxxxxx.intranet.fw) at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._initEngine_privact(EngineImpl.java:165)
19:06:49,537 STDERR [stderr] (asxxxxxx.intranet.fw) at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.doStartup(EngineImpl.java:138)
19:06:49,537 STDERR [stderr] (asxxxxxx.intranet.fw) at com.pega.pegarules.web.servlet.WebAppLifeCycleListener._contextInitialized_privact(WebAppLifeCycleListener.java:280)
19:06:49,538 STDERR [stderr] (asxxxxxx.intranet.fw) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
19:06:49,539 STDERR [stderr] (asxxxxxx.intranet.fw) at java.lang.reflect.Method.invoke(Method.java:606)
19:06:49,539 STDERR [stderr] (asxxxxxx.intranet.fw) at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:338)
19:06:49,539 STDERR [stderr] (asxxxxxx.intranet.fw) at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:379)
19:06:49,539 STDERR [stderr] (asxxxxxx.intranet.fw) at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:216)
19:06:49,540 STDERR [stderr] (asxxxxxx.intranet.fw) at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:265)
19:06:49,540 STDERR [stderr] (asxxxxxx.intranet.fw) at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
19:06:49,540 STDERR [stderr] (asxxxxxx.intranet.fw) at org.apache.catalina.core.StandardContext.contextListenerStart(StandardContext.java:3339)
19:06:49,540 STDERR [stderr] (asxxxxxx.intranet.fw) at org.apache.catalina.core.StandardContext.start(StandardContext.java:3780)
19:06:49,541 STDERR [stderr] (asxxxxxx.intranet.fw) at org.jboss.as.web.deployment.WebDeploymentService.doStart(WebDeploymentService.java:163)
19:06:49,541 STDERR [stderr] (asxxxxxx.intranet.fw) at org.jboss.as.web.deployment.WebDeploymentService.access$000(WebDeploymentService.java:61)
19:06:49,541 STDERR [stderr] (asxxxxxx.intranet.fw) at org.jboss.as.web.deployment.WebDeploymentService$1.run(WebDeploymentService.java:96)
19:06:49,542 STDERR [stderr] (asxxxxxx.intranet.fw) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
19:06:49,542 STDERR [stderr] (asxxxxxx.intranet.fw) at java.util.concurrent.FutureTask.run(FutureTask.java:262)
19:06:49,542 STDERR [stderr] (asxxxxxx.intranet.fw) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
19:06:49,542 STDERR [stderr] (asxxxxxx.intranet.fw) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
19:06:49,543 STDERR [stderr] (asxxxxxx.intranet.fw) at java.lang.Thread.run(Thread.java:745)
19:06:49,543 STDERR [stderr] (asxxxxxx.intranet.fw) at org.jboss.threads.JBossThread.run(JBossThread.java:122)
19:06:49,762 INFO [org.jboss.as.server] (Controller Boot Thread) JBAS015859: Deployed "SFDCGATEWAY.war" (runtime-name : "SFDCGATEWAY.war")
19:06:49,762 INFO [org.jboss.as.server] (Controller Boot Thread) JBAS015859: Deployed "prgateway.war" (runtime-name : "prgateway.war")
19:06:49,762 INFO [org.jboss.as.server] (ServerService Thread Pool -- 34) JBAS015859: Deployed "prweb.war" (runtime-name : "prweb.war")
19:06:49,763 INFO [org.jboss.as.server] (ServerService Thread Pool -- 34) JBAS015859: Deployed "prhelp.war" (runtime-name : "prhelp.war")
19:06:49,772 INFO [org.jboss.as] (Controller Boot Thread) JBAS015961: Http management interface listening on http://xx.xx.xx.xxx:9990/management
19:06:49,772 INFO [org.jboss.as] (Controller Boot Thread) JBAS015951: Admin console listening on http://xx.xx.xx.xxx:9990
19:06:49,773 INFO [org.jboss.as] (Controller Boot Thread) JBAS015874: JBoss EAP 6.4.21.GA (AS 7.5.21.Final-redhat-1) started in 351711ms - Started 533 of 559 services (90 services are lazy, passive or on-demand)
19:15:51,622 INFO [com.hazelcast.nio.SocketAcceptor] (hz._hzInstance_1_668e03f97c14a138d2c4267ce8ce03b2.IO.thread-Acceptor) [xx.xx.xx.xxx]:5702 [668e03f97c14a138d2c4267ce8ce03b2] [3.2] Accepting socket connection from /xx.xx.xx.xxx:40515
19:15:51,624 INFO [com.hazelcast.nio.TcpIpConnectionManager] (hz._hzInstance_1_668e03f97c14a138d2c4267ce8ce03b2.IO.thread-Acceptor) [xx.xx.xx.xxx]:5702 [668e03f97c14a138d2c4267ce8ce03b2] [3.2] 5702 accepted socket connection from /xx.xx.xx.xxx:40515
19:17:51,954 INFO [com.hazelcast.nio.TcpIpConnection] (hz._hzInstance_1_668e03f97c14a138d2c4267ce8ce03b2.IO.thread-in-2) [xx.xx.xx.xxx]:5702 [668e03f97c14a138d2c4267ce8ce03b2] [3.2] Connection [/xx.xx.xx.xxx:40515] lost. Reason: java.io.EOFException[Remote socket closed!]
***Edited by Moderator Marije to add Support Case Details***
