Rabo Bank
Last activity: 17 Jan 2018 14:24 EST
Problem Mapping data when using Case Creation API
I am facing problem while creating cases using Pega case creation API.
"caseTypeID": "Jxx-Location-Work-Example",
"processID": "pyStartCase",
"ClipboardPage": [{"PropertyName":"Property Value", "pxobjclass":"Jxx-Location-Data-Example"}]
In the above example, the Property Value is not getting set to the Clipboard Page.
Please suggest if there is anything wrong with the Syntax or any way to map the data from clipboard properly.
Vinoth
