Problem with Exit point in automation
Problem 1:
I am raising the event in my automation and then after firing raising event, my automation is not doing further operation. please guide me for further solution. If after raising the event I can do further operation or automation then my problem will be resolve. I will not face problem 2
Problem 2:
To over come I have done some work around, but then it leads to another issue, that is its not exiting from Automation.
As a solution I tried below things:
Raising the Event like below:
it was opening some pop up, so using Created event of that pop up
Then I want to exit from the automation ,but its holding the thread I believe.
Problem 1:
Problem 2:
Exit is not hitting after Created Event.
Please help me on this ASAP.
If you are expecting a created event to occur and want to handle it in the same thread you need to use a WaitForEvent. This allows you to wait on the current thread. WaitForEvent is accomplished by dropping the Created event on the automation surface, right-click on it and choose Wait for this event. From the Setup yellow dot do the actions that will cause the event to happen.
It looks like you have to many execution paths on your automation as well. If you are exiting from an Exit Point (Exit1 or Exit2) then you should not exit from True and False or vice versa.
