Equivalent to Application.Exit() in C# for an automation?
For an automation is there an equivalent to Application.Exit() in C#?
Thanks.
Thanks.
If you want existing from automation use Entry and Exit (will display by right clicking in the automation window)
If you want exist from application (means adapters) use Start and Stop properties of adapter.
If you want exist from entire automation process use RuntimeHost.TerminateRuntime under Runtime tab in toolbox.
