Ordina
Last activity: 11 Jul 2024 8:46 EDT
Problem with custom button
I saved a modelled button as a custom button, pretty standard: Strong button with a text and an icon.
The original button in a section has the label space reserved because of alignment issues.
If I convert the original button to 'my' saved variant it won't reserve the blank label space as it would as it's original. Nothing else was modified on the custom button it is just a saved-as version of a button as described above.
How can I solve this?
Hi @Bertus_ten_Hoor,
Could you give a try to Save as the Button control in pega that belongs to the RS Pega-Gadgets:08-07-01 I believe that would resolve the issue. Also if required you can edit the HTML code to incorporate the necessary changes in your custom button.
