Accenture
PH
Last activity: 28 Dec 2016 15:40 EST
Preview when creating a correspondence is not working
We need guidance with this issue: When we click the preview button while we are creating a correspondence, it is not working.
You may see attached screenshot for reference.
Please advise.
Dar Ganata
Accenture Australia
Hi Darwin,
It will work fine but i didnt get why its not showing. Please create new correspondence and it again. It will work fine in the latest versions.
Please attach screenshots if you are getting errors.
Thank you.
Are rules included are available? What is exception you are observing, please post a screenshot.
Try previewing any OOTB corr rule, to verify.
Accenture
PH
Thanks for your response, but as per checking there are no exceptions when i click the preview button.
I'm really sorry but can you guide me on how can i try previewing any OOTB corr rule as you suggested?
Thank you so much,
Dar Ganata
Hello
is it happening with all correspondance rule or only this one ?
If it is happening with only this one then try deleting the referenced rule and see that makes any difference or not.
Most of the time , if your referenced rules are not available then correspondance failed to show them during preview .
Accenture
PH
Thank you so much for your response. But as per checking, the preview problem is happening to all of the correspondence rule.
Please advise what actions can i take to resolve this issue.
Thanks you so much.
Which PRPC version you are on and on which browser you are trying out this ?
Accenture
PH
Im using PRPC 6.3 on Internet Explorer 11
TCS
In Pega 7,under actions preview is available. In Pega 6, there is an icon to preview.Run the tracer and click on it to identify where its failing.
