PickOperator Control Not Working
I added the Pick Operator control to my section, which lets you select from all operator IDs in the application for routing, and its function is inconsistent. When I preview or run the section, it works perfectly, but when I actually use the section in a flow action it does not work at all. I traced the event in the flow action, and when I click on the control or press the down arrow (which usually shows all the options), nothing happens in the tracer. I don't know if there is another way to troubleshoot this issue or if I am just implementing it incorrectly but any help is appreciated!
