Accenture Solutions Pvt Ltd
Perform Click not working on object got identified as a button in OpenSpan
I am trying to Perform Click on a button(PFA screenshot) by using raise event as well, though it is able to focus on it & but not able to performclick.
Pravallika.
Can you try interrogating the button with the interrogation form drop-down set to "Select Element"? See if there is a hyperlink (A tag) under the button that you can interrogate instead. The PerformClick may work there.
Actually am not getting <A> tag when interrogating button in SelectElement mode only am able to see <Button>,<DIV> .Please help to solve ,even tried with hidden control also, but still performclick is not working for the button, where as it is working when I tested with Test Target Methods.
Pravallika.
I suspect your issue is that the website doesn't know you've set the text in the search box and therefore the button is disabled. Try raising the OnChange or OnKeyUp events on the text box before you click the button. You may have to examine the HTML of the page to see which events are being triggered. Let me know if that doesn't work and I can try to get it to work here since your site seems to be public.
Hi
I tried raising the Onchange and Onkeyup event on the text box but still its not working. Kindly try it from your end and share the screenshot of the working automation. Site-URL : https://www.flipkart.com/
Pravallika
I was unable to resolve this with anything quick that I tried. It appears as though the site is using some JS that requires any changes be also propagated up to parent DIVs. You might want to open a SR to have this looked at with a member of support as this may require some time and effort to investigate.
As suggested by Thomas, you may go ahead with creating an SR for your query. The following article will be helpful for reference-
My Support Portal explained for Pega Robotic Automation (formerly OpenSpan)
Let us know the SR number here within the thread so that we can tag it along with the thread.
Hope the information is helpful.
Bank Of America
Hey,
Did this get resolve? I am facing similar issue.
Hello @RavindrasinhS6010,
We recommend that you create a new post for your question as this post does not have a resolution updated.
Thanks!
