Pega Smart Investigate for Payments 8.6 any hotfixes available/ issues Field75/ 77 and 79 of MT199
In SI,Swift message vaidation is not as per swift standards.Is there any hotfix available for Swift standard validations
****************** Description updated by Moderator to include actual issue logged in INC-A26085 ***************
Field79 of MT199 does not accept double back slash "//".
This is not a correct SWIFT validation format. It should accept // as per SWIFT standard.
Steps to reproduce
We need to click on swift correspondence and selete respective message type and send the swift correspondence
Problem description:
FIELD 79 OF MT192 – Request Cancellation of our Payment - Without Code TEMPLATE
PLEASE FIX THE NUMBER OF LINES OF FIELD 79 OF MT192 TO MAXIMUM OF 35 LINES (AS PER SWIFT STANDARD).
PLEASE ADD THE BELOW AS A FIXED TEXT INSIDE THE BOX OF FIELD 79 OF MT192, BEING THE FIRST 3 LINES"
PLEASE URGENTLY CANCEL THE BELOW MENTIONED PAYMENT ORDER AND RETURN THE FUNDS TO OUR ACCOUNT UNDER SWIFT CONFIRMATION TO US
FIELD 79 OF MT199 – GENERAL PURPOSE MESSAGE TEMPLATE
PLEASE PUT INSIDE THE BOX, THE LAST 3 LINES OF FIXED TEXT, WHICH IS CURRENTLY OUTSIDE THE BOX.
THEN, PLEASE FIX THE NUMBER OF LINES OF FIELD 79 OF MT199 TO MAXIMUM OF 35 LINES (AS PER SWIFT STANDARD), INCLUSIVE OF THE 3 LINES FIXED TEXT.
Steps to reproduce
LIMIT THE NUMBER OF CHARACTERS FOR EACH LINE, AS PER SWIFT STANDARDS AMD ONCE IT EXCEEDS THE LIMIT, IT SHOULD GO AUTOMATICALLY TO THE NEXT LINE (KINDLY NOTE EACH FIELD HAS DIFFERENT REQUIREMENT FOR NUMBER OF CHARACTERS
FIELD 75 - PLEASE FIX THE NUMBER OF LINES OF FIELD 75 OF MT195 TO MAXIMUM OF 6 LINES (AS PER SWIFT STANDARD) AND MAX OF 35 CHARACTERS FOR EACH LINE
FIELD 77 - PLEASE FIX THE NUMBER OF LINES OF FIELD 77 OF MT195 TO MAXIMUM OF 20 LINES (AS PER SWIFT STANDARD) AND MAX OF 35 CHARACTERS FOR EACH LINE. (PLS NOTE NO ERROR PROMPTED/ SWIFT VALIDATION FOR FIELD 77A)
FIELD 79 – PLEASE FIX THE NUMBER OF LINES OF FIELD 79 OF MT195, AS PER SWIFT STANDARDS, MAX LINES IS 35 AND MAX OF 50 CHARACTERS FOR EACH LINE.
MT196 WITHOUT CODE SWIFT VALIDATION FORMAT :
FIELD 76 - PLEASE FIX THE NUMBER OF LINES OF FIELD 76 OF MT196 TO MAXIMUM OF 6 LINES (AS PER SWIFT STANDARD) AND MAX OF 35 CHARACTERS FOR EACH LINE
FIELD 77 - PLEASE FIX THE NUMBER OF LINES OF FIELD 77 OF MT196 TO MAXIMUM OF 20 LINES (AS PER SWIFT STANDARD) AND MAX OF 35 CHARACTERS FOR EACH LINE
FIELD 79 – AS PER SWIFT STANDARDS, MAX LINES IS 35, PEGA ALLOWS UP TO 28 LINES ONLY AND MAX OF 50 CHARACTERS FOR EACH LINE.
***Edited by Moderator Marije to add INC***
